So my Pi sits in a cupboard so I can remote into it when needed and use SSH.
What I found was if I remote in with XRDP I can't get the LAN settings.
Editing netplan doesn't seem to work.
I have to login to the machine locally to edit those IP settings in the GUI.
Is there SSH commands I can use to edit the IP settings? Static IP, DNS, Gateway etc.
I assume you run Ubuntu Mate on the pi and say, its ip is 192.168.1.100 You are able to ssh to the pi and would like to modify ip. You can edit the netplan file in /etc/netplan with sudo.
Change the ip to 192.168.1.200, make sure your netplan is correct, and reboot. The pi will have this new ip and you can ssh to the new ip. The old ip is gone.
I tried that and makes no change. Once saved it gets listed as a new eth01 in network config in the GUI below the LAN that is in use. Reboot has no effect. It's like it gets the network settings from a different config?
Everything I read says netplan should control it, but doesn't do anything for me.
I run netplan test, and apply, reboot but in network config it still shows LAN and then netplan-eth01. No change to system IP via netplan.
if your physical interface is eth0, why do you want to change it to eth01? you cannot rename a physical interface, if your system says eth0, that's it. Unless you modify rules in /etc/udev/rules.d/
are you trying to make an alias? that would be eth0:0 or eth0:1
Any time you modify netplan, activate with sudo netplan apply
commands ifconfig or ip a will show the immediate changes.
Is your system a DNS server? nameservers: tag has google or other public DNS
nameservers:
[tab] addresses: [8.8.8.8, 8.8.4.4]
