What is ZSWAP
Zswap is a Linux kernel feature providing a compressed write-back cache for swapped pages. Instead of moving memory pages to a swap device when they are to be swapped out, zswap performs their compression and then stores them into a memory pool dynamically allocated inside system’s RAM.
You can read more about it in this Beginner friendly introduction.
ZSWAP has been merged into the 3.11 mainline linux kernel, but is not turned on by default.
Benefits
ZSWAP will make very efficient use of swap. It will minimizes Disk I/O by both reducing the number of writes and reads required (data is compressed and held in RAM) and by reducing the bandwidth of these I/O operations as the data is in a compressed form. Thus you will not face sudden slowdowns when your system runs out of memory and tries to read/write the swap drive.
For whom it wont work
- Who does not have a SWAP partition
- People with less than 1ghz CPU speed
- People who uses ZRAM
For whom this tweak will work
- People who have a dedicated SWAP partition / SWAP file
- People with low system memory
Steps to enable ZSWAP
- Check if your OS Kernel comes with ZSWAP by running the command below.
If the response isCONFIG_ZSWAP=y
, you are OK to proceed.
cat /boot/config-`uname -r` | grep -i zswap
- Open grub as admin
gksu pluma /etc/default/grub
- Change the line
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
to
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash zswap.enabled=1 zswap.compressor=lz4”
- Save, close Pluma. Update Grub by running
sudo update-grub
- Enable lz4 (for very fast compression/decompression)
sudo su
echo lz4 >> /etc/initramfs-tools/modules
echo lz4_compress >> /etc/initramfs-tools/modules
update-initramfs -u
Restart your PC.
Check if ZSWAP is enabled by running (Mentioned by @1Q7FE6zp)
cat /sys/module/zswap/parameters/enabled
If ZSWAP is enabled, you should see Y
in return.
To check if LZ4 compressor is being used run
dmesg | grep -i zswap
Check the last line of the response. If the result says
[ 0.715381] zswap: loaded using pool lz4/zbud
Then voila ! You’ve successfully enabled ZSWAP.
