I’ve got a problem. I need to use two SPI’s on my raspberry pi 3b, but I’m not able to make the SPI1 work. I’ve edited the config.txt to enable the SPI’s moreover I did as told on the raspberry forum - disable the bluetooth. So i’ve added the following lines to the config.txt:
dtparam=spi=on
dtoverlay=pi3-disable-bt
sudo systemctl disable hciuart
dtoverlay=spi1-1cs
But I’m only able to detect the SPI0. Could someone please help me?
