I've posted about such 'paper cuts' before, over a period of several years - and nothing about this has really gotten any better from what I can see.
Conundrum:
I'm here alone - using MY own PC - and I plug in USB device 'x'...
Does it read & appear ?!?
To get the answer - roll some yes/no dice !!
(And watch the contradictions appear.)
Desire:
Same situation - same action...
Device is read and appears - PERIOD.
Best/worst example:
A genuine gripe as well here=>
I have a truly beloved app 'My Phone Explorer' - and yes, it is a windoze app with no Linux version because it's dev KNOWS that it runs fine via WINE.
Yes - that much is true - but minus the ability to simply plug in an Android device & have it recognized & appear is the problem - that doesn't happen.
Yes, of course I looked into this problem and found all sorts of higglety-pigglety gobbledeegoop that one might TRY in order to get past whatever restrictions that the OS imposes by its nature - and I even tried some of the ideas - to no avail.
So what do I have to do when I wish to access an Android device simply & easily ??
I have to fire up a windoze instance on my workbench box for using this ONE freeware app.
I call BS on this problem !!!
My stuff - I am trying to use it - no home invasion here - but does my otherwise wonderful U/M PC accomodate such a timely & basic need ?!?
Not even slightly.
Do I wish to embark upon endless patchy attempts to just 'unlock' my own PC's USB ports for NORMAL uses ??
Ridiculous. Absurd.
This should NOT even be a problem - it should not even need to be mentioned here because in truth it SHOULD JUST WORK, always, PERIOD.
Disclaimer:
I -exclusively- use U/M 365 days/year EXCEPT when it has a FUBAR situation like this - which FORCES me to gain satisfaction by using that OTHER OS - which I would totally prefer NOT TO NEED anymore for anything.
