The panel button ‘Configure Display Settings’ can be enabled through System > Preferences > Hardware > Displays > Show monitors in panel.
Icon when clicked with EITHER right or left mouse displays the rotation options for each of the current monitors, plus a link to Configure Display Settings … Ie. it’s the same for both.
Suggest ONE of left or right click (right?) takes you directly to Configure Display Settings, while the other (left?) remains exactly as now.
This would make it as easy to, say, turn off a monitor or change which is primary, as to make a rotation change.
TIA!
