I installed pulse audio equalizer.
When I ran qpaeq, I get this message.
There was an error connecting to pulseaudio, please make sure you have the pulseaudio dbus module loaded, exiting...
Is there a fix or some other equalizer that works ?
Hi fixIt7,
try installing the package "pulseeffects" which may help?:
sudo apt install pulseeffects
PulseEffects is an advanced system-wide equalizer that works with PulseAudio. It can apply system-wide effects to all running application or selected apps.
PulseEffects also provides many pre-defined sound effects for PulseAudio input and output.
There are also several extra package recommendations!.
Thanks so much. PulseEffects has its own equalizer.
Is this solved now?.
