When Ubuntu MATE 16.04 starts, and before in 15 as well, I see two Errors passing by:
Error to load Braille Modules
Error to load Kernel Modules
Most things work (except Bluetooth and audio, but that seems to be a common problem). Sometimes I get an error message while using Ubuntu, but it doesn’t interrupts any process as far as I notice.
says: ExecutablePath > usr/bin/gnome-keyring-daemon.
I don’t know if both errors are related.
Nobody else has this problem??
No suggestions to solve this?
Dis93
29 April 2016 16:37
3
I’ve the same two errors on boot on my Pi 3B with 16.04.
I get
systemctl status britty.service
● britty.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
and
systemd-modules-load.service - Load Kernel Modules
Loaded: loaded (/lib/systemd/system/systemd-modules-load.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2016-04-29 17:10:17 BST; 3min 32s ago
Docs: man:systemd-modules-load.service(8)
man:modules-load.d(5)
Process: 73 ExecStart=/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
Main PID: 73 (code=exited, status=1/FAILURE)
Apr 29 17:10:16 pibuntu systemd-modules-load[73]: Failed to find module ‘lp’
Apr 29 17:10:16 pibuntu systemd-modules-load[73]: Failed to find module ‘ppdev’
Apr 29 17:10:16 pibuntu systemd-modules-load[73]: Failed to find module ‘parport_pc’
Apr 29 17:10:16 pibuntu systemd-modules-load[73]: Inserted module ‘snd_bcm2835’
Apr 29 17:10:17 pibuntu systemd-modules-load[73]: Inserted module ‘bcm2708_rng’
Apr 29 17:10:17 pibuntu systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE
Apr 29 17:10:17 pibuntu systemd[1]: Failed to start Load Kernel Modules.
Apr 29 17:10:17 pibuntu systemd[1]: systemd-modules-load.service: Unit entered failed state.
Apr 29 17:10:17 pibuntu systemd[1]: systemd-modules-load.service: Failed with result ‘exit-code’.
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
in Terminal.
[ FAILED ] to load Kernel modules
[ FAILED ] to load Braile modules
Have also spotted this on the bootscreen with 16.04 on pi2.b
Everything seems to work fine though.
You have sound and bluetooth working?
I don’t…
(it DID work in the beta version though).
I face the same issue. Is there any solution yet?
Greetings
similar issue. hangs on UI for a while, Running the latest 16.04.1 LTS from the page for PI.
For me the UI hangs in the loading screen with a message along the lines of ‘wlan 0 issue’ .
Decided to use a different OS until resolved.
skyway
15 September 2016 14:36
8
Same error here with the modules, everything seems fine though. Sound and hdmi ok
