Right. You can't access the "whole" drive of a mounted drive that way. You can access the file system, root (/), with the "File System" icon. Unmounted file systems can be accessed that way though:
I can access any of the ST3160815AS:ROOT icons, and they will mount as normal, because they are currently unmounted by the system meaning they are not listed in /etc/fstab. I cannot access the WDC WD10EZEX-00BNSA0 drive because partitions of that drive are mounted and listed in /etc/fstab.
Oh, I see. Looks like It’s just different from Windows
I’m glad, that everything is working properly, though.
Thanks a lot for explanation and help! Really appreciate that
I would expect that double click on a device listed in fstab will just trigger its mounting according to the definitions in fstab and then behave like the drives which are not defined by fstab.
Is that achievable?
If not, once I define a device on fstab what would be the simplest way to trigger its mounting (In case I set noauto in fstab)?
