After following the above steps i am in much worse situation. The screen is now freezing with the error - missing lowerdir. Not sure what should be the next step.
Hi, @Vinamra and welcome to the Ubuntu MATE Community!
Vinamra,
These steps were not intended for your usecase.
For starters, according to the hardware info you submitted, you have a completely different computer and a totally different problem. The result is, therefore, not really a surprise.
This often translates as "disk-full-error"
Try make some more free space on the root partition of your harddrive.
No guarantees but it might just work
check also this:
So we know exactly what hardware is being looked at, can you provide the report from:
inxi -G
Make that
inxi -F
i have a hunch we're going to need it ![]()
I think there is enough space -
"test@vinamra-Recoil-VI-17:*
df
er
Filesystem
1K-blocks
Used
Available Use% Mounted on®
tmpfs
3259868
3152
3256716
1X
/run
/dev/nvneinipl
95584500
19887744
70747696
22%
tmpfs
16299328
16299328
0%
/dev/shm
tmpfs
5120
12
5108
1% /run/lock
efivarfs
192
118
70
63%
/sys/firmuare
/dev/nvmeon1p1
262144
33848
228296
13%
boat/efi
/dev/nme1n1p2 767864576
475550740
253234976
66% /home
tmpfs
3259864
84
3259780
1% grun/user/ 1001"
Thanks, but there is one slight problem.
This table is mangled beyond recogition.
I'm afraid i'm not willing to start to decypher that.
If you want to share output, just copy/paste from terminal directly into a message, preferrable marked with the </> tag.
But nevermind.
run from a terminal:
inxi -F
and copy/paste the output in a message here
to everyone here who uses Ubuntu 24.04 LTS and Ubuntu 24.10 LTS. Do not use the LTS versions of Ubuntu, they are not yet stable enough and often lead to system problems in everyday use.
Stay with Ubuntu 24.04 or Ubuntu 24.10 and do not upgrade.
I hate to be the one to point out the obvious, but UM 24.04 is by definition, an LTS version, and only the first release in that release family.
Don't know how anyone would even begin to think otherwise.
So to advise staying with UM 24.04 vs UM 24.04 LTS seems, to me at least, a statement that makes no sense at all! ![]()
