Hi. Just wondering if it is possible to add ethernet status sign (connected/disconnected) to the top panel of ubuntu-mate 20.04, as it used to be in earlier versions. Thanks!
Welcome to the Ubuntu MATE community, @alexx!
Yes, there are quite a few indicators you can add to the Ubuntu MATE panel, including ethernet status. Here are the step-by-steps:
- Right-click on the panel where you want to add the indicator and select Add to Panel....
- Scroll down the list, select Network Monitor and click the Add button.
- You can close the Add to Panel dialog box.
- Right-click on the new indicator to see the options that are open to you. You can change what information is displayed, move the indicator, and even lock it in place.
I hope that helps.
Thanks. It would be nice if i could hide those speed digits and only show arrows. It used to look so in previous releases...
