Ethernet & WiFi networks not connecting
Hello Ubuntu Mate, I am Joseph A Cacciola.
having a 2 problems in my system Ubuntu 16.04 LTS: -
  1. Ethernet Disconnected
  2. WiFi Network is Disabled
Please let me know how can I fix this problem? I already try some things but still not succesful.
Waiting for your response,
Kind Regards;
Joseph A Cacciola
These are the only commands I have for Network Manager and I am not sure they are what you need nonetheless I will drop them off for ya to have
sudo systemctl restart network-manager.service
sudo service network-manager restart
sudo stop network-manager
sudo start network-manager
Please right click your desktop and select "Open in terminal".
Then use the following command:
inxi -N > network.txt
This will create a file network.txt on your desktop.
Please save it to a USB stick, and use another computer to give us the content of the file.
Cheers
Thanks you so much my friends for the help, I already try this and that time having a same problem after rebooting my machine but the next day mean right now automatic problem resolved. I don’t know how it’s happen.
