Execute sh-files in a terminal by double-click, is it possible?
In the settings I have only the option "execute", but if I choose ask all ways, I will get an option box with the additional option "open a terminal and execute".
Is it possible to configure for double click : "open a terminal and execute" (etc, config file) ?
Start Caja file manager. Select Edit > Preferences. Switch to Behaviour tab and select desired action to accompany opening of executable text files.
Yes of course but there is missing the option : "open a terminal and execute".
Its better to see what I mean, set ask all ways what to do, and if done you will get after double click an "option frame" with an option button :"open a terminal and execute"
Now I have found a solution :
Added to script (found at linux mint forum) :
#!/bin/bash
# if the script was not launched from a terminal, restart it from a terminal
if [[ ! -t 0 ]] && [[ -x /usr/bin/mate-terminal ]]; then
	/usr/bin/mate-terminal -e "bash -c \"$0 $*; read -s -p 'Press enter to continue...'\""
	exit
fi
And set in caja "execute" by double click-
A terminal will be opened and the respective script performed.
Glad you have found solution.
I'd like to note that there is such the option named Run in Terminal (UM 22.04):
The caveat is that terminal is immediately closed when a script in question terminates. I.e. the script has to pause its execution. Pausing is usually implemented with read command. It is enough to add read -n 1 -s at the last script line.
