I run the official ubuntu 19.10 image for the gpd micro pc. My system is up to date.
My issue is that connecting the device to an external display does not work anymore (it used to work). When I connect a VGA screen (with an hdmi-vga adapter) nothing happens, my screen does not react, nothing shows up in dmesg. When I plug my hdmi videoprojector (which used to work too), my gpd 6' screen is changed (as if an external screen has been detected) but the external display still says 'no signal'.
I've got this in dmesg [drm:mipi_exec_gpio [i915]] *ERROR* GPIO index 1 request failed (-2) after I plug the hdmi display, but I don't think it's related.
Here is the result of xrandr with nothing plugged OR with a VGA external display plugged with an adapter :
$ xrandr
Screen 0: minimum 8 x 8, current 1280 x 720, maximum 32767 x 32767
DSI1 connected primary 1280x720+0+0 right (normal left inverted right x axis y axis) 0mm x 0mm
720x1280 60.08*+
640x480 59.94
720x405 59.51 58.99
360x640 60.00
640x360 59.84 59.32
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Here is the result of xrandr with an hdmi display plugged :
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1800, maximum 32767 x 32767
DSI1 connected primary 1280x720+301+1080 right (normal left inverted right x axis y axis) 0mm x 0mm
720x1280 60.08*+
640x480 59.94
720x405 59.51 58.99
360x640 60.00
640x360 59.84 59.32
HDMI1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1280x800 59.81 +
1920x1080 60.00* 60.00 50.00 50.00 59.94 24.00 23.98
1920x1080i 60.00 50.00 59.94
1680x1050 59.88
1280x1024 75.02
1440x900 59.90
1366x768 59.79
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 119.99 75.03 70.07 60.00
800x600 119.97 72.19 75.00 60.32 56.25
720x576 50.00
720x576i 50.00
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 119.99 75.00 72.81 66.67 60.00 59.94
The vga and hdmi external displays both works fine with another debian computer.
What could I do to further investigate the issue ?
