Hey guys,
I’ve just tried running Minecraft, but I’m getting a fatal error when I attempt to do so. I installed the application from the Software Boutique, but I also tried downloading the JAR from the Minecraft site - both have the same issue.
I’m running Mate 18.04 x64 on a Thinkpad X1 Carbon.
I did some Googling around before coming here, and numerous solutions said to try renewing my ca certs, but this didn’t work. Here is the recommended command:
sudo update-ca-certificates -f
Has anyone else had this issue that can help me get Minecraft working on my machine please? TIA!
Below is the terminal output from when I start Minecraft:
Bootstrap (v5)
Current time is May 1, 2018, 7:37:08 PM
System.getProperty('os.name') == 'Linux'
System.getProperty('os.version') == '4.15.0-20-generic'
System.getProperty('os.arch') == 'amd64'
System.getProperty('java.version') == '10.0.1'
System.getProperty('java.vendor') == 'Oracle Corporation'
System.getProperty('sun.arch.data.model') == '64'
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma
Exception: javax.net.ssl.SSLException: java.lang.RuntimeException: Unexpected error: java.security.InvalidAlgorithmParameterException: the trustAnchors parameter must be non-empty
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 2/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 3/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 4/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 5/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 6/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 7/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 8/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 9/10)
Downloading: https://s3.amazonaws.com/Minecraft.Download/launcher/launcher.pack.lzma (try 10/10)
Unable to download remote file. Check your internet connection/proxy settings.
FATAL ERROR: net.minecraft.bootstrap.FatalBootstrapError: Unable to download while being forced
at net.minecraft.bootstrap.Bootstrap.execute(Bootstrap.java:95)
at net.minecraft.bootstrap.Bootstrap.main(Bootstrap.java:381)
Please fix the error and restart.
