Continuing the discussion from Apt Security - Ubuntu MATE 16.04 action required:
Are there any updates regarding the SpiderOakONE package? When trying to install it through the Software Boutique I get this error message:
@maro did is not the same issue as with Google. That is a gpg key issue. This just states that the package doesn’t exist. You could try to searching for it in a terminal :
apt search spideroak
Make sure Welcome is subscribed to updates, then reinstall SpiderOak using Software Boutique. This will grab the updated signing key.
