Hi there,
and first of all thanks for ffpyplayer! It's very powerful to have …these bindings :)
I noticed an issue with the latest version (4.5) of ffpyplayer relating to playing the audio streams from _certain_ video files: When starting to play the video, no audio can be heard and the following error is logged:
[ffpyplayer_abuffersink @ 0x600003f30210] Channel layout change is not supported
Audio thread error: Not yet implemented in FFmpeg, patches welcome
As hinted upon in [this reddit thread](https://www.reddit.com/r/kivy/comments/13x8p4y/ubuntu_audio_problems/), downgrading to 4.3.5 indeed helped: The audio plays as expected, emitting only the following log message in place of the one above:
[ffpyplayer_abuffersink @ 0x600002fe8790] Removing channel layout 0x3, redundant with 2 channels
The video plays fine via `ffplay`, including audio, so I would have expected ffpyplayer to also play it without issues.
Is there something between v4.3.5 and 4.5 that might have caused this error? Was this a deliberate change?
I don't know the codebase really, but I'm happy to dive into this, if it helps.
Python 3.10.12, macOS 13.4.1
```python
ffpyplayer.player.MediaPlayer(
video_url,
lib_opts={},
ff_opts=dict(sync="audio", ss=0, infbuf=True),
$ ffprobe video.mp4
ffprobe version 6.0 Copyright (c) 2007-2023 the FFmpeg developers
built with Apple clang version 14.0.3 (clang-1403.0.22.14.1)
configuration: --prefix=/opt/homebrew/Cellar/ffmpeg/6.0 --enable-shared --enable-pthreads --enable-version3 --cc=clang --host-cflags= --host-ldflags= --enable-ffplay --enable-gnutls --enable-gpl --enable-libaom --enable-libaribb24 --enable-libbluray --enable-libdav1d --enable-libmp3lame --enable-libopus --enable-librav1e --enable-librist --enable-librubberband --enable-libsnappy --enable-libsrt --enable-libsvtav1 --enable-libtesseract --enable-libtheora --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libxvid --enable-lzma --enable-libfontconfig --enable-libfreetype --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libspeex --enable-libsoxr --enable-libzmq --enable-libzimg --disable-libjack --disable-indev=jack --enable-videotoolbox --enable-audiotoolbox --enable-neon
libavutil 58. 2.100 / 58. 2.100
libavcodec 60. 3.100 / 60. 3.100
libavformat 60. 3.100 / 60. 3.100
libavdevice 60. 1.100 / 60. 1.100
libavfilter 9. 3.100 / 9. 3.100
libswscale 7. 1.100 / 7. 1.100
libswresample 4. 10.100 / 4. 10.100
libpostproc 57. 1.100 / 57. 1.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x13c804ae0] st: 0 edit list: 1 Missing key frame while searching for timestamp: 1000
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x13c804ae0] st: 0 edit list 1 Cannot find an index entry before timestamp: 1000.
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'video.mp4':
Metadata:
major_brand : XAVC
minor_version : 16785407
compatible_brands: XAVCmp42iso2
creation_time : 2023-05-16T22:35:07.000000Z
Duration: 00:02:23.04, start: 0.000000, bitrate: 98555 kb/s
Stream #0:0[0x1](und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709/bt709/iec61966-2-4, progressive), 3840x2160 [SAR 1:1 DAR 16:9], 96812 kb/s, 25 fps, 25 tbr, 25k tbn (default)
Metadata:
handler_name : Video Media Handler
vendor_id : [0][0][0][0]
encoder : AVC Coding
Stream #0:1[0x2](und): Audio: pcm_s16be (twos / 0x736F7774), 48000 Hz, 2 channels, s16, 1536 kb/s (default)
Metadata:
handler_name : Sound Media Handler
Stream #0:2[0x3](und): Data: none (rtmd / 0x646D7472), 204 kb/s (default)
Metadata:
handler_name : Timed Metadata Media Handler
timecode : 14:54:11:01
Unsupported codec with id 0 for input stream 2
