Filemanager is unable to write to rw filesystem
On startup I mount samba cifs in fstab RO to avoid accidental writing.
  1. I startup Filemanager.
  2. I do the mount -o remount,rw /media/smb
  3. Filemanager does not understand that it is RW now.
  4. Exit Filemanager and run it again.
  5. Filemanager shows it can write but when I try to copy or create file IT FAILS with an error that Filesystem is readonly
At this moment I can create/copy/write in terminal and Midnight Commander without any problem.
If I do not startup Filemanger but first do RW and only after that startup FileManager then everything is OK.
Is it a bug or such a nice feature?
I should say it comes a long time ago(more than 5 years) and on every Ubuntu.
Am I alone discovered this feature?
Is there a workaround? Should I kill something after each mount -o remount?
Hi @dnm2dnm ,
sounds like a permissions problem?, are you sure you are the owner of the files?. :smiley:
You might find something useful here?:
https://help.ubuntu.com/community/Samba
It could be a caching issue, try pressing F5 a few times inside that folder.
Otherwise, kill off the file manager: (it auto respawns)
Press ALT+F2 then type:
killall caja
It is not permission problem because everything is OK in terminal.
Reload never helped in any ubuntu.
Exit filemanager never helped in any ubuntu.
killall caja DOES HELP which is very convenient. :slight_smile:
Thank you!
And caja -q will restart Caja.
caja -q and killall caja looks working the same.
The interesting thing that the “feature” :slight_smile: stops working that way after first restart/killing caja.
After that Caja just closes the device which was remounted - also convenient stuff. But thank you God it allows to write. :slight_smile:
Very glad to meet the leader of the project!
Just to mention I started to use Mate a year ago and moved into it on all my systems.
I got familiar with Mate on Raspberry PI. Many thanks to that device for it.
Thanks to everybody for the help.
This looks a lot like this bug.
