I set up VirtualBox and installed todays daily mate iso using zsync.
/media/pfeiffep/ExtData/VirtualBox/MATE$ zsync http://cdimage.ubuntu.com/ubuntu-mate/daily-live/current/yakkety-desktop-amd64.iso.zsync
1 error on install then 1 error on update. I didn't see the install error in syslog
I changed the source to main form US with same results
Need to alert @lah7 as I think that; that is his baby?.
There is no Yakkety source. This is one of the reasons the welcome center will not work.
https://launchpad.net/~ubuntu-mate-dev
Thank you! It saves me the time eliminating my VirtualBox ignorance
Advance users catch on fast, you will see
OK, this is my second daily install in VirtualBox. Iām posting this from 16.1
This message came up early in the install
ubi-console-setup crashed exit code1
more information will be in /var/log/syslog
try again continue quit
I tried again 1 time with the same error and then continued with good results.
I searched the syslog for exit and did NOT fine code 1. I suspect this error might be related to installing in VirtualBox
Ich habe vergessen Ziffer nul
Perhaps I was typing a bit too quickly ⦠bit I suppose you probably REALLY understood
Just messing with you Peter!.
Here's s screen capture of the failure on install in a Virtual Box. This time I decided to try prior to install:
Also I decided not to try again and clicked on continue anyway
I was uncertain whether the ubi-console message was a result of VM or the the iso. I installed Ubuntu 16.04 and all went well - no error.
I received the same message installing to a SSD. I tried twice also and then continued anyway. Seems to work OK!
