Just a question: what exactly it repairs? steam is running quite well for me currently, only problem is that I do get a popup about missing files, which I click-off without further problem.
It’s if you have issues installing, as the install fails from the software boutique:
So, instead sudo apt install steam from the terminal, then apply fix when launcher fails but as yours is running it’s moot
