If you have Librewolf installed there is a chance that around this time the Update Manager will "fail" to update Librewolf.
Using sudo apt update from the commandline gives more information:
If you encounter this:
E: Repository 'https://repo.librewolf.net librewolf InRelease' changed its 'Origin' value from 'LibreWolf Software Repository' to 'Staging LibreWolf Software Repository'
N: Repository 'https://repo.librewolf.net librewolf InRelease' changed its 'Suite' value from 'LibreWolf Software Repository' to 'Staging LibreWolf Software Repository'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
Do you want to accept these changes and continue updating from this repository? [y/N]
Press 'y' to accept these changes.
Usually the 'staging' repository is a bit more experimental than the 'stable' repository but I guess the people behind Librewolf had their reasons.
Now you can update as usual again.
(The same happened in Debian Trixie, see: #2075 - Debian Trixie with extrepo: Repository 'https://repo.librewolf.net librewolf InRelease' changed its 'Origin' value from 'LibreWolf Software Repository' to 'Staging LibreWolf Software Repository' - librewolf/issues - Codeberg.org )
In case you have a totally different error, like update warnings because librewolf gpg key expiration, read this:
