For some reazon i can't get flash to work in Opera i have all the necessary packages installed and still nothing. Any suggestions? I realy like Opera and it worked great in my machine, but i have to stop usin it if i don't fix this
Hi @farenasutem,
open Synaptic and search “adobe”, find the other plugin (not the flash installer but the adobe-plugin) and double click it to install, it will remove the flashplayer installer but that is okay!.
To install Synaptic via the terminal (Ctrl + Alt + t):
sudo apt-get install synaptic
Hope it helps.
