Focal installed - panels don't load icons
Having a problem displaying icons on launchers that refer to files on a different HD to the OS.
Checking on Disks and Edit mount options shows that the HD is set to autoload.
In actual fact it doesn't autoload and therefore the image files used for the launcher icons don't load.
it might be a problem with the theme you are using?. Did you use a standard theme or something else?. :blush:
Thanks wolfman
  No, I use Radiant-Mate, the only customisation used is the
DMZ-Red pointer.
  BTW.  I have used the exact same config for the panels, icon
graphics and poiter for the last 4 years on 16.04 without any
problems.
Thant's why I am surprised now.
Franz
OK, I figured it out: There MUST be an entry at "Display Name" on Mount Options.
The name becomes appended automatically after "gvfs-show, ..."
