When using LibreOffice Writer, the font changes in my table whenever I tab to another box.
I then have to change it back to DejaVu Sans.
Is there a way to force it to use a user defined font for my entire document?
There's a one of two ways:
The font will then stick as the table cells have been instructed to use a particular font, instead of the default.
Alternately, the "cleaner" way is to edit the styles for the document.
