I installed FOXIT and LyX and R .Nothing is displayed in the main menu.Please help me with this. Last time everything seems to be working fine.
I installed foxitreader and it shows a link in Applications | Office Everything was installed in /opt (mate 15.10)
Thanks a lot for the eye opener!
I did change the instalation path to opt/ now it seems to working fine.
Hi @Aga,
please mark as solved so it helps others with the same problem, tick @pavlos_kairis’s answer as best answer!. Thanks.
Could anybody please explain the above to a simple me? The way of "sudo ..."
Thank you. Igor
