Have an old laptop that was running 16.04 without a problem. I did a fresh minimal install of 18.04 and now there is no wifi being detected. No wifi was available during installation, so I thought it may be fixed post-installation. But now I'm running it, I can't figure out how to enable WiFi. Pressing Fn+F3 on the keyboard which is supposed to activate wireless connectivity does not work either. Help, please!
You need to let it run for up to a few minutes. This is what my MacBook looks like, which does not have wi-fi after a new install (with the wi-fi driver installed):
It shows the same Broadcom driver as yours (sans the Airport Extreme part). The difference is, the text underneath it says "This device is not working." and "Do not use the device" is selected.
So, I tried selecting the driver, selected "Apply Changes" but it has been 40 minutes and nothing has happened. Seems like it has hanged. I Closed the window and I'm back to where I started with "Do not use the device" selected.
I think that's the normal text before the driver is installed
But I don't know why applying the change would take so long. Have you used the wifi in another OS recently? I have seen a similar behavior with a failed wifi card.
Not that I know of. It worked perfectly fine on 16.04.
So, I am trying to install again. I am able to choose the broadcom driver and activate it. But the installer shows the "Enable Wifi" option not with a check but with something like a white square before it. (Will try to get a screenshot later).
