You could simply install ubuntu-mate-desktop
and that should pull in meta and core, but bear in mind if you’re not using LightDM for your login manager already, it’s probably going to request superseding that.
That, and you’ll have two of everything in your hard drive; one for your current DE and another for MATE. It’s honestly a lot less hassle and significantly less messy to just overwrite your installation. However if you do not have a separate partition dedicated to /home
you will need to cp ~
in its entirety to another device. That or use mv
instead but cp
will prevent potential issues with losing files due to corruption and / or read errors from the device is hosted in.
After, you’ll either had learned your lesson and made another partition for /home
or copy everything from your external device back to ~
contained in /
. Remember; since all of the Ubuntus are just Debian at their core, it doesn’t matter what system you have installed; /home
will not be overwritten with some other nonsense except for stuff required by the system, and most of your configuration files from all the programs you need to reinstall will still be there, making the process of getting back onto your feet with a different flavour of Ubuntu a painless procedure (so long you remember what PPAs you had and the package names of all the software you want to use).
Far as partitioning, you can use gparted
first, then use the parts you made there later. Most people only need 32GB for the system, unless they’re doing game stuff; if you intend to use Steam, allocate either another 150-200GB for larger titles, or 1) make a different library for your games at another partition, or 2) symbolically link the default directory with ln
after you move it. For Steam it should just be ~/.steam
you need to move.
Mind that for Fedora, if you want to move away from Ubuntu for any reason you are at the mercy of Anaconda for partitioning, part of the reason why I dislike Anaconda for Fedora, versus Ubiquity for Ubuntu. Just be sure in Ubiquity that you assign each partition the same type as what’s already there and not to format the existing /home
partition, should you already have one. /
can eat it since that’s where the system will live. Post-installation, just do everything you did beforehand, with tweaks and adjustments to your workflow as necessary for MATE.
