GDM error on ec2 instance with DCV
Hello,
I have set up an ec2 instance with ubuntu 24.04 and then installed ubuntu-mate-desktop and set up DCV. I can log in through DCV but then the display just stales at the loading animation.
Running
journalctl -b -u gdm shows the lines
Gdm: GdmDisplayStore: Adding display /org/gnome/DisplayManager/Displays/97236947544576 to store
Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
and
Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
**Gdm: Child process -1155 was already dead.**
Any idea what is failing?
cat /etc/X11/default-display-manager
/usr/sbin/gdm3
BTW: I was able to get it to work with ubuntu-desktopinstead of mate
Hi, @diophantus7 and welcome to the Ubuntu MATE Community!
It might be the fact that Ubuntu uses the Wayland protocol for displaying a desktop while Ubuntu-MATE uses the X11 protocol which is completely different.
I guess DCV is oblivious to the fact that it now has to talk the X11 protocol on a Ubuntu VM besides the fact that i don't even know if it is able to support X11 at all.
OTOH, I might be completely mistaken because I have no Idea how DCV connects to the graphical server ( also I've never even heard of DCV before).
There's also the possibility that GDM and MATE aren't playing nicely together in this use-case. You could try switching to lightdm.
You should also look for support directly from the developers (or other users) of EC2 and DCV.
I do have Wayland disabled in /etc/gdm/custom.conf. That is also suggested by AWS for the gnome desktop.
That's what I was thinking too. On the other hand I have been using GDM with MATE. But from what I remember that is on ubuntu 22.04 or even 20.04.
Also I can add, that when I set everything up with Gnome (working) and then install ubuntu-mate-desktop, I cannot go back to Gnome. The login stays at the loading indicator as it does with MATE. Not sure if that helps anyhow.
Yeah, some files and settings don't get reverted when a desktop (package) is removed. I'm not an expert in switching between desktops because I avoid it like the plague. Others around here can hopefully chime in.
