Get fan speeds and other hardware info
I had sensors working in 18.04 but having difficulties with 20.04
I installed sensors and ran sensors-detect selecting the default choices.
I would appreciate the opportunity to learn what I need to do next.
sensors
k10temp-pci-00c3
Adapter: PCI adapter
temp1:         +2.1°C  (high = +70.0°C)
                       (crit = +80.0°C, hyst = +79.0°C)
radeon-pci-0008
temp1:         +2.0°C  (crit = +120.0°C, hyst = +90.0°C)
fam15h_power-pci-00c4
power1:           N/A  (crit =  65.19 W)
And my hardware info. Not sure if you need other info.
sudo dmidecode | more
Base Board Information (Mother board)
    Manufacturer: Gigabyte Technology Co., Ltd.
    Product Name: F2A68HM-H
BIOS Information
        Vendor: American Megatrends Inc.
        Version: FB
        Release Date: 04/22/2015
AMD A8-7600 Radeon R7, 10 Computer Cores 4C+6G x 4
Trying some other things.
 E: Package 'hddtemp' has no installation candidate
Psensors shows hd temps but  does not show fan speeds.
Not sure but think gkrelim has fan speeds. In repository.
https://www.makeuseof.com/tag/easily-monitor-your-system-with-gkrellm/
Thanks, it did not have fan speeds.
I am no longer worried about it.
