Anyway, how can I make them smaller?
This is on a Dell latitude 2120, 1366x768 resolution.
open caja and open "edit/preferences" and check you icon size is set to the default of 100%
If it is, then navigate to your desktop inside Caja and click on "view/zoom out" until you desktop icons are the correct size
