Gigabyte Aviva K8100 wont work
Im trying to get my K8100 Keyboard to work but everything I am finding is from 2012 or older and dose not fix the issue. I am running 15.04 and the only key that works is the backspace key but the keyboard works fully in the BIOS and on another box running Windows 7. Anyone have a suggestion?
I've just read somewhere that you need to press:
shift+ctrl+alt+n
I'm sure you will have already tried that, but just in case.....
Yeah first thing I tried but thanks anyway.
Sorry I couldn’t be more use to you Telemont
Dont apologize im really not expecting much i spent an hour trying to get this working a few days ago. Its a gaming keyboard that I will just leave hooked up to the gaming rig and not bother with synergy.
