I want to run gparted to format a usb flash drive. When I run it I see the bottom panel showing “Starting GParted”. After a few moments it disappears and nothing else happens.
When I run gparted via terminal, here is what I get:
Created symlink /run/systemd/system/-.mount → /dev/null.
Created symlink /run/systemd/system/boot-efi.mount → /dev/null.
Created symlink /run/systemd/system/run-user-1002.mount → /dev/null.
Created symlink /run/systemd/system/tmp.mount → /dev/null.
/usr/sbin/gpartedbin: error while loading shared libraries: libgtkmm-2.4.so.1: cannot open shared object file: No such file or directory
Removed /run/systemd/system/-.mount.
Removed /run/systemd/system/boot-efi.mount.
Removed /run/systemd/system/run-user-1002.mount.
Removed /run/systemd/system/tmp.mount.
Any ideas how to fix this?
P.S. I’m on 16.10
