Great distro - some ideas
Thank you for this great distro!
I have recently installed Ubuntu Mate 18.04.1 and i'm really happy.
Since this section is called Thoughts & Feedback, i would consider the following:
  1. The audio volume indicator on the panel: in my previous distro, lubuntu, pressing the middle mouse button was enought to mute it. I think it would be nice.
  2. Terminal default config: ubuntu 18.04 non mate has a nicer prompt imho. i don't think it will waste that much resources, but i think it could be a good improvement.
  3. themes and panel. I'm currently using redmond theme, with only a lower panel. If i make it tiny (24 pixel) some icons and notification are clipped on the lower and higher part.
  4. cosmetical... some icons on the panel are bigger than others.
  5. i have tried the live on a Lenovo L380. This is a Linux general problem, but imho the trackpad is too fast. Windows (yes...) allows to choose a much lower speed. I think sometimes it could be nice.
  6. Again, congratulations to all the developers and keep up the great work!
Great thoughts. Agreed
I'm trying to get prompt with colors
the .bashrc is the same as ubuntu 19.04 that features a color prompt... i don't know why.
Anyhow, to get a color prompt just uncomment force_color_prompt=yes in that file.
I really don't agree with comments! A visible prompts imho really helps to understand things.
# uncomment for a colored prompt, if the terminal has the capability; turned
# off by default to not distract the user: the focus in a terminal window
# should be on the output of commands, not on the prompt
I have seen that point 1,2,3,4 have been addressed in the future 20.04 lts release!
Thank you and keep up the great work!!!
