http://cdimage.ubuntu.com/ubuntu-mate/daily-live/current/
Mate is the only flavour still showing as focal fossa 20.04
Very true.
I tried to grab the Ubuntu-MATE daily ISO tonight based on a script last used during focal cycle, and failed.
I then went to http://iso.qa.ubuntu.com/qatracker/milestones/413/builds hoping for clues.. none found
(in case it's useful, I noticed the same (not on iso.qa..) with Lubuntu (& others) 3-4th May, Laney responded (#ubuntu-devel) a typo in a config file was found which led to it being fixed for us; but we still had ISOs before that fix..)
Sorry for the delay. There was a slight misconfiguration that was causing the builds to fail. This has been resolved and new 20.10 test ISO's should be available tonight.
All working fine now.
Copied the folder to my Ventoy setup 64GB USB stick groovy folder.
