I noticed that in Grsync, the boxes for owner and permissions are not checked off.
Is there a reason for that?
Does Backup do the same?
And when a restore is done, are the permissions and owner lost?
If your saving to a Ext4 formatted disk or partition your permissions and ownership will stay in tacked. If your saving to a NTFS or FAT formatted disk or partition your permissions and ownership will be lost. This is Linux foundational.
However, if you restored a file from the Ubuntu mate backup utility (Deja Dup), I believe at that point the file would be owned by the account that you restored it to. Kind of like copying a system file to your home folder, it becomes yours.
Mine are being save to a ext3 hard drive.
Hallo fixit7
You may find this video useful:
If you run into a UID-problem grsync can be a useful tool, as you can choose to "switch-off" preserving permissions.
Deja-dup, the backup software included in Ubuntu-Mate make "compressed", "incremental" backups - you need a copy of deja-dup to access the backup again. With grsync you can make an uncompressed backup that you can access from any attached Linux computer. My personal backup strategy uses both. ![]()
