My Pi 3B+ with ubuntu mate 16.04.5 displays no sensors found after adding the hardware sensors monitor panel applet. I confirmed that mate-sensor-applet, mate-sensor-applet-common. libmate-sensors applet-plugin0 are all installed.
I am trying to duplicate the raspbian stretch temperature monitor display on the panel. It looks like the hardware sensor monitor mate panel applet is supposed to do just that and even more.
I realize that I can simply type vcgencmd measure_temp in terminal to get the cpu temp but I would prefer to have the panel applet working. Any ideas?
If the mate applet can’t do this (and I haven’t used it in years) then it wouldn’t be hard to write a custom plugin https://github.com/mate-desktop/mate-sensors-applet/tree/master/plugins . This would be a nice little project for somebody. Essentially you would take an existing plugin like smu-sys and adapt it for your needs.
Thanks stillwater for the Raspberry Pi 2 Sensor link. I ended up using the command panel applet option with the following command:
awk ‘{printf “%3.1f°C\n”, $1/1000}’ /sys/class/thermal/thermal_zone0/temp
The output is perfectly simple and does exactly what I wanted. Being able to set the update interval is an added benefit. Thanks Dude!
