I just installed MATE from a Ubuntu Server 18.04 Cloud Image and im having all sorts of problem.
I nstalled Ubuntu-Mate from tasksel.
When MATE started up i didnt have a login screen.
I then went into Software & Updates. When trying to change something it saids:
You are not allowed to perform this action
You don't have the required privileges to perform this action.
org.freedesktop.PolicyKit.Error.Failed: ('system-bus-name', {'name': ':1.83'}): org.debian.apt.update-cache
I then installed Welcome screen and software-boutique because it was missing:
snap install --classic ubuntu-mate-welcome
snap install --classic software-boutique
I then rebooted but they didnt show up in the menus, but welcome screen showed up, so i entered the software-boutique from there.
Depending on what i click on it saids:
org.freedesktop.PolicyKit.Error.Failed: ('system-bus-name', {'name': ':1.70'}): org.debian.apt.install-or-remove-packages
or
org.freedesktop.PolicyKit.Error.Failed: ('system-bus-name', {'name': ':1.70'}): org.debian.apt.upgrade-packages
I can't apply any of the fixes for my sourcelist or broken packges in there
I checked for 'PolicyKit Authentication Agent' in the Startup Apps to see if it was there.
And there was a entry '/usr/lib/x86_64-linux-gnu/polkit-mate/polkit-mate-authentication-agent-1'
How ever running:
sudo /usr/lib/x86_64-linux-gnu/polkit-mate/polkit-mate-authentication-agent-1
from the Terminal gives me:
(polkit-mate-authentication-agent-1:2450): polkit-mate-1-WARNING **: 11:05:47.527: Unable to determine the session we are in: No session for pid 2450
I then went into Control Center to check 'Login Window'. However clicking it didnt do anything.
