My HDD's is always make silent clicking-clackin sound in idle. It's really annoying. If i copying or writing on the HDD sound has gone while the process taking. On windows or non ubuntu based linux (like fedora) everything is fine. HDD SMART is OK.
I tried do
sudo hdparm -B 255 /dev/sda1
and write it to end of the
/etc/hdparm.conf
but not working. If i go hdd to suspend, or set APM (in disk application) the sound still exist.
The clicking sound is usually caused by the drive parking its head(s) because of “aggressive” power management settings by the firmware. HDD models targeted for laptop use (Hitachi Travelstar, WD Green, some Samsung and Toshiba models…) are known to have this “feature”. Some Thinkpad BIOSes also try to force the “optimum” settings for power saving (parameter -B) every time AC state changes.
The solution, of course, is to reset the APM mode, which is what we are trying to do here, with the hdparm settings.
In other words: problem is with the HDD (or BIOS setting the HDD parameters), not file system . And definitely no reason to reinstall.
Their power management includes code that overrides the parameters by default and Debian/Ubuntu does not?
It’s quite easy to verify if unloading the head is the cause. After each click run:
$ sudo smartctl -A /dev/sda|grep 'Load_Cycle_Count'|awk '{print $10}'
If the count increases, there’s your culprit.
The clicking could indicate a drive about to fail, but if it makes the click in one OS only, it’s most likely APM issue and easy to fix with hdparm. This is a well known issue.
I wonder if setting APM using hdparm is supported by your drive at all. This will tell you:
$ sudo hdparm -B /dev/sda
If not supported, you get back something like:
/dev/sda:
APM_level = not supported
The Load_Cycle_Count seems a bit high, how does that compare to Power_Cycle_Count?
$ sudo smartctl -A /dev/sda|grep -E 'Power_Cycle_Count|Load_Cycle_Count'
In a drive suffering from the “agressive APM settings problem” Load_Cycle_Count is multitudes bigger than Power_Cycle_Count (on one of my drives: 1519 / 41005) while a “normal” drive has the ratio closer to 1/2.
The drive in my Thinkpad T520 makes somewhat annoying clicking noises in idle… and it’s an SSD… Not sure what’s really causing the noise. It’s worse when I’m slouching on the sofa and generally stops when the laptop base is dead horizontal. It really sounds like disk accesses though. And yes it really is a pure SSD, not a hybrid or a fake.
Just saying. that even if it really sounds like it is, maybe it’s not the HDD at all.
