HDMI Monitor switch
i'm use a hdmi switch to connect two pc's to one screen. After switch back to the mate 23.04 pc "black screen" and no idea to reactivate the screen. Only reboot works.
Thanks for any help.
Cons of HDMI Switches
Often, a device needs to be turned on and off for the HDMI switch to transmit the signal properly. Another problem is that you can also lose image quality with some connected devices.
