When I'm using my headphones and listening or watching something on any browser at some point a loud noise starts to sound. This is not happening only while I use a browser, it happens too while using VLC Player or other applications. But mostly happens with a browser.
The audio starts normal but a few seconds/minutes later the audio is distorted and a loud noise starts and doesn't stops until I pause the audio for a while.
I recorded this. I leave a link to a sample:
This started after a recently fresh install of Ubuntu 20.04. Started using Unity desktop and switched to Mate desktop a few hours later.
I can't confirm if this happened while using Unity because I didn't used my headphones back then. I can't confirm either if this happens with speakers because I don't have any to do the test.
This doesn't happen when I'm using Windows 10 on the same computer.
All drivers are up to date and tried purging Pulse Audio, Alsa and reinstalling and rebooting.
I've tried other solutions in other posts but none seem to work all most of them have a similar issue but not exactly my issue.
