Im not able to mount any drive on my laptop. I dont know why.
I have only 1 disk on my laptop which is sda, have 4 partition, 1 for root ext4, 1 for swap, 1 for data ext4, and 1 ntfs.
normally, it should mount the ntfs drive when clicked but at some point it doesn't do that anymore, instead it gave me error.
temporarily solution for now is
sudo mkdir /media/external
sudo mount -t ntfs /dev/sda2 /media/external -o uid=1000,gid=100,utf8,dmask=027,fmask=137
i dont really know what the code does, I just copied it from some places, it just works. why did this happened? I need a permanent fix. that code just now is to mount my ntfs drive only which is located in sda2, i dont know how to mount flashdrive using the same method.
