Hahel
18 September 2022 16:05
1
Hi guys,
I installed Foxit Reader software cause I used it to have for editing pdf documents when I had Windows 10.
It worked well, but it is not updating the version and now freezes when I open any file.
I am trying to uninstall unsuccessfully.
Does anyone have an idea how to do it?
Thanking you in advance.
PS: I am new to Linux, and I am still learning.
Hahel
18 September 2022 21:01
3
Here is the website I used to guide me through the installation.
This is a proprietary app that uses its own installer. I suggest you remove the whole /opt/foxitsoftware/ dir and remove anything in the .local/share/Foxit dir. They should have provided an uninstall tool.
rm -rf ~/opt/foxitsoftware/foxitreader/
rm -rf ~/.local/share/Foxit*
Hahel
18 September 2022 21:53
5
I used the commands you wrote down...
The subfolders were deleted from opt and I restarted the PC. The Foxit is still installed and working. Even so, the folders are not in the opt anymore.
Very weird.
Did you install in /opt or per the article in .opt (the dot makes a difference). If so,
rm ~/.opt/files......
Hahel
19 September 2022 20:34
7
This directory doesn´t exist.
mendy
19 September 2022 20:42
8
Maybe see if it is installed with Ctrl Alt T and then
dpkg -l
Can scroll with down arrow or page down and look for fox???
Can hit x close when done.
Edit
Disregard this site seems to state it can't be found in this manor.
https://forums.foxitsoftware.com/forum/portable-document-format-pdf-tools/foxit-reader/168699-cannot-uninstall-foxitreader-on-linux
try this:
sudo updatedb
locate foxit
It should list the various directories where foxitsoftware is. The list could be long.
If you can paste the output here, it will help to decide how to delete.
Hahel
16 December 2022 22:18
10
The command ¨sudo updatedb..." was not found.
I installed ¨plocate¨ command using ¨sudo apt install plocate¨
The list the command gave me is:
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/Wrappers/en-US/Wrapper.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libFRMS.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libcloudloginplugin.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libcloudreading.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libconnectedpdf.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libconnectedpdfdrm.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libconnectpdfservice.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libcpdfad.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libfpcsdk.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/librms.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/librmsauth.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/librmsauthWebAuthDialog.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/librmscrypto.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/librpc.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/fxplugins/libupdater.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/imageformats/libqgif.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/imageformats/libqjpeg.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitActivate.ico
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitActivate.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-128x128.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-16x16.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-24x24.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-32x32.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-48x48.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-64x64.ico
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader-64x64.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReaderInstall-48x48.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReaderInstall-64x64.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitReaderInstall.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitUninstall-48.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitUninstall.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitUpdate-48.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/FoxitUpdate.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/images/foxitreaderactivate.ico
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/ko_kr
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/readerlite_zh_cn.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_cn
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_tw
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/ko_kr/qt_ko_KR.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/ko_kr/readerlite_ko_kr.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_cn/qt_zh_CN.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_cn/readerlite_zh_cn.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_tw/qt_zh_TW.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lang/zh_tw/readerlite_zh_tw.qm
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/.directory
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libFcitxQt5DBusAddons.so.1
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libFcitxQt5DBusAddons.so.1.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Core.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Core.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Core.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Core.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5DBus.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5DBus.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5DBus.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5DBus.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Gui.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Gui.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Gui.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Gui.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Network.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Network.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Network.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Network.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5OpenGL.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5OpenGL.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5OpenGL.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5OpenGL.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Positioning.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Positioning.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Positioning.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Positioning.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5PrintSupport.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5PrintSupport.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5PrintSupport.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5PrintSupport.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Qml.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Qml.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Qml.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Qml.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Quick.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Quick.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Quick.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Quick.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5QuickWidgets.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5QuickWidgets.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5QuickWidgets.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5QuickWidgets.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sensors.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sensors.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sensors.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sensors.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sql.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sql.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sql.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Sql.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKit.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKit.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKit.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKit.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKitWidgets.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKitWidgets.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKitWidgets.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5WebKitWidgets.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Widgets.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Widgets.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Xml.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Xml.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Xml.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5Xml.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5XmlPatterns.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5XmlPatterns.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5XmlPatterns.so.5.3
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libQt5XmlPatterns.so.5.3.2
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libcrypto.so.10
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libffi.so.5
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgcrypt.so.11
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstapp-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstapp-0.10.so.0.25.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstbase-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstinterfaces-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstinterfaces-0.10.so.0.25.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstpbutils-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstpbutils-0.10.so.0.25.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstpbutils-1.0.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstpbutils-1.0.so.0.403.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstreamer-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstreamer-0.10.so.0.30.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libgstvideo-0.10.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libicudata.so.52
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libicui18n.so.52
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libicui18n.so.52.1
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libicuuc.so.52
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libicuuc.so.52.1
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libsecret-1.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libsecret-1.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libssl.so.10
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libxkbcommon.so.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libxkbcommon.so.0.0.0
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libxslt.so.1
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libxslt.so.1.1
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/lib/libxslt.so.1.1.26
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforminputcontexts/libcomposeplatforminputcontextplugin.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforminputcontexts/libfcitxplatforminputcontextplugin.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforminputcontexts/libibusplatforminputcontextplugin.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqeglfs.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqico.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqlinuxfb.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqminimal.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqminimalegl.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqoffscreen.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platforms/libqxcb.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/platformthemes/libqgtk2.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/printsupport/libcupsprintersupport.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/mime
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/128x128
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/16x16
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/24x24
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/32x32
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/48x48
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/64x64
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/128x128/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/16x16/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/24x24/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/32x32/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/48x48/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/icons/64x64/FoxitReader.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/resource/mime/FoxitReader.xml
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/rmssdk/librms.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/rmssdk/librmsauth.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/rmssdk/librmsauthWebAuthDialog.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/rmssdk/librmscrypto.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/sensors/libqtsensors_dummy.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/sensors/libqtsensors_generic.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/sensors/libqtsensors_linuxsys.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/sqldrivers/libqsqlite.so
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Arrow Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Arrow Stamp(Deep Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Arrow Stamp(Deep Green).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Arrow Stamp(Green).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Arrow Stamp(Purple).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Circle Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Diamond Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Diamond Stamp(Green).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Ellipse Stamp(Green).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Ellipse Stamp(Purple).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Ellipse Stamp(Red).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Octagon Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Octagon Stamp(Purple).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Rectangle Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Rectangle Stamp(Deep Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Square Stamp(Green).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Square Stamp(Purple).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Triangle Stamp(Blue).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/Standard Templates/Triangle Stamp(Purple).pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps/Approved.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps/Confidential.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps/Received.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps/Reviewed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Dynamic Stamps/Revised.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here/Accepted.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here/Initial.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here/Rejected.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here/Sign Here.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Sign Here/Witness.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Approved.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Completed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Confidential.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Draft.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Emergency.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Expired.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Final.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Received.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Reviewed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Revised.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Verified.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/en-US/Standard Stamps/Void.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps/Approved.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps/Confidential.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps/Received.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps/Reviewed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Dynamic Stamps/Revised.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here/Accepted.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here/Initial.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here/Rejected.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here/Sign Here.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Sign Here/Witness.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Approved.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Completed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Confidential.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Draft.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Emergency.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Expired.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Final.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Received.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Reviewed.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Revised.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Verified.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/stamps/zh-CN/Standard Stamps/Void.pdf
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/images
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/proceed.html
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/setting.html
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/images/graphic.jpg
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/images/icon_i.png
/timeshift/snapshots/2022-12-13_23-00-03/localhost/opt/foxitsoftware/foxitreader/welcome/images/logo-l.png
I see timeshift has /opt/foxitsoftware/ Was foxitsoftware installed as a snap pkg? if sudo snap list lists foxitsoftware, then sudo snap delete foxitsoftware should work.
If not, you may have to delete /opt/foxitsoftware and everything below that dir.
