Hi. Before I installed Ubuntu MATE 16.04.1 64bit, I was a Ubuntu Unity user where I did not have these issues…
I have a 1920x1080(60hz) that now is 1024x768(76hz) and I cannot change it to any other resolution.
It had my native resolution at first when I installed MATE and when I rebooted after all the updates being done from the Welcome screen, it turned into 1024x768
Also, when I bring up ‘Nvidia X Server Settings’, all it shows me is the “Application Profiles” and “nvidia-settings Configuration” tab.
(In the ‘Software & Updates’ I have set the Intel to microcode firmware and the nvidia to version 361.42 (proprietary, tested)).
I have a GTX 960 and i5 6500.
Also took a look at MATE Tweak window compositors and all I had was "Marco(No compositor) and “Marco(Software compositor)”. Or is it like that by default without compton and compiz?
Installed Steam and tried to run it and after it had updated it shows a message: OpenGL GLX extension not supported by display
If something wasn’t clear enough, please let me know and I’ll try to explain further!
This looks like something is wrong with your driver installation - that Steam error and the absence of Compton/Compiz in MATE-Tweak show that 3D acceleration is not working.
Check the troubleshooting section of the binary driver how-to.
I did a clean install on Ubuntu 16.04.1 again and setup the additional drivers to it’s proprietary, rebooted and it worked flawlessly. I then again did a clean install on Ubuntu MATE 16.04.1, did the same thing and not working.
(Not dualboot)
It’s pretty sad actually as I was so tempted to use MATE. I really liked it but this problem really surprised me, I wish it wasn’t like this.
I’ll go back to Ubuntu Unity for now.
Hope there’s a solution somewhere, I couldn’t find it after searching for 6 hours.
Hi @wolfman ! It didn't seem to do anything. I wrote the commands you gave me after the install of MATE, and also after applying changes to the drivers in Additional Drivers and also after the restart.
I only got this message:
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I assume that since you have done a fresh install; the commands won’t do anything?.
What type of media did you use to do your install?, if a disk, did you burn the disk at the slowest speed and if a USB install, did you fully format the USB drive first?.
Ignore the warning and continue, you should delete all partitions with FAT32 but if you used the “Startup Disk Creator”, you might want to try formatting it under Windows if you have it on your PC!. (I have had trouble with formatted USB sticks that were first done with Startup Disk Creator myself!).
Then use Startup Disk Creator again and it should auto-format the drive!.
If you can; I recommend that you download a fresh ISO and start completely from the beginning again!, that is of course up to you. If you do download a fresh ISO, download it from a different location than the last one you downloaded!.
Most likely the same as above?:
You can also try Unetbootin but it requires a FAT32 pre-formatted USB stick!:
Solved!!! All I did was installing both the updates and Flash, MP3 etc before installation and turning off Secure Boot with the MOK Manager appearing after restart.
I won the fight, the PC can’t win over me lol
