hello newbie here,
need help about my mate-terminal. after doing this tutorial , my terminal wont open
Thanks in advance
hello newbie here,
Thanks in advance
I think this will work...
Open up Applications -> System Tools -> dconf Editor
Navigate to org.mate.terminal.profiles.default (I assume this is the bad profile)
Uncheck use-custom-command. Hope this gets it.
thank you very much, this solve the problem
Fantastic! I love it when a plan comes together.
