Hi, just reinstalled UM 14.04.2 32 bit on my main machine after messing about too much with previous installation. However, upon re-installation with latest 14.04.2, samba does not appear to be working anymore.
Installed samba GUI and set up my shares in it in the usual manner.
Added line to all samba entries in smb.conf file in etc/samba. The line being "force user = stephen" (where stephen is my user name). All that is usually required, at that point, is a reboot and the shares should be visible/browsable from the network places menu, However, all that is appearing is a windows network icon that requires a password. In other words, the server and all of the shares it contains is not there.
Been on the net looking for solutions, but all they tell me to do is what I have already done. At a loss now and need some further advice.
For completeness, here are the smb.conf entires:
[software]
comment = Software
path = /media/stephen/Store1/software
writeable = yes
; browseable = yes
guest ok = yes
[Videos-1]
comment = Videos-1
path = /media/stephen/Store1/Videos-1
writeable = yes
; browseable = yes
guest ok = yes
[Videos-2]
comment = Videos-2
path = /media/stephen/Store2
writeable = yes
; browseable = yes
guest ok = yes
[Videos-3]
comment = Videos-3
path = /media/stephen/Store3
writeable = yes
; browseable = yes
guest ok = yes
Also, I should add, since installing 14.04.2, last night, huge number or error messages appearing at login to do with panels, marco and lightdm. I assumed they would diminish as updates took place and, although they have a little, still getting quite a lot of them. Don't know if this is related to my network problem but thought I should mention it
