Ĩm new to linux , so heads up.
bluetooth shows but when searching for devices, it finds nothing.
Sound does not work either.
pixi@pixi-T100TAF:~$ dmesg | grep -i firm
[ 0.113571] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.261253] [Firmware Info]: PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] not reserved in ACPI motherboard resources
[ 0.302268] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.754316] ACPI: thermal: [Firmware Bug]: No valid trip found
[ 8.312396] sof-audio-acpi-intel-byt 80860F28:00: Firmware info: version 1:6:0-e9637
[ 8.312409] sof-audio-acpi-intel-byt 80860F28:00: Firmware: ABI 3:17:0 Kernel ABI 3:18:0
[ 8.622001] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43340-sdio.ASUSTeK COMPUTER INC.-T100TAF.txt failed with error -2
[ 8.622487] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43340-sdio.txt failed with error -2
[ 8.811302] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43340/2 wl0: Oct 23 2017 08:41:23 version 6.10.190.70 (r674464) FWID 01-98d71006
What do i need to do? I found a BCM43341B0.hcd and put that in the firmware folder, but that made no difference...
