Very new to Linux (3 Days).
I'm trying to install HamSphere 3, from a .jar file. I get a message telling me that,
"The file '/home/john/Desktop/hamsphere_3.1.5.jar' is not marked as executable. If this was downloaded or copied from an untrusted source, it may be dangerous to run."
I've spent a few Days searching for a solution and have tried everything I can find, from marking the File as an executable, to several methods using the Terminal. All to no avail.
I would be very grateful, if anyone could help me with this problem.
I'm using Ubuntu 18.04.4 LTS Mate Desktop.
Try this command:
java -Xmx256m -DEMPATH=/home/john/Desktop -jar HamSphere_3.1.5.jar
You will need java runtime packages. I use OpenJDK packages -
openjdk-8-jre-headless:amd64
-and-
openjdk-8-jre:amd64
djb
@JohnC The issue is that you may have openjdk-11 ...
I started a UM 18.04 VM,
sudo apt install openjdk-8-jdk
java -jar ./hem3.jar started right away.
Thanks for your reply.
I've got the Java Packages. When I typed that into the Terminal, it's returned this:
Exception in thread "main" java.lang.NoClassDefFoundError: org/omg/CORBA/portable/IDLEntity
Here's the Java info:
openjdk version "11.0.6" 2020-01-14
OpenJDK Runtime Environment (build 11.0.6+10-post-Ubuntu-1ubuntu118.04.1)
OpenJDK Server VM (build 11.0.6+10-post-Ubuntu-1ubuntu118.04.1, mixed mode, sharing)
As I said, I'm very new to Linux (about 4 Days) and I must admit, I'm struggling a bit.
Do I need the Version 8 Packages, or is it something else causing the problem?
As I said, I'm very new to Linux, so tbh I'm not too sure about the UM 18.04 VM part.
Can I also install Version 8, or should I do away with the Version that I have already first?
I managed to install Hamsphere 4 (which came as a tar.gz file), I'm a bit concerned that I may do something to this, as it's an updated Version of HamSphere 3, if I need to use an older Version of Java.
Please excuse my ignorance.
I've just installed Java 8 and marked the HamSphere .jar File as executable in Properties. When I right click and open with Java 8, nothing happens. I think I'm missing something about the process.
Let's make sure you have java 8 ... java -version should tell you.
Also, dpkg -l | grep openjdk should list what is installed.
From a terminal, java -jar ham3.jar (adjust for the correct filename) and it starts
ham4 is better than ham3 but it still needs openjdk-8 ... see what @Dave_Barnes wrote.
Right. CORBA was removed in newer OpenJDK versions. You will need version 8 for HamSphere.
You can have multiple versions of java, you need to tell the system which one to use. It seems you have java 11 (like my system) so first I installed 8 ... sudo apt install openjdk-8-jdk
sudo update-alternatives --config java should list the versions you have (in my case 0 is auto mode, 1 is 11 and 2 is 8. I selected 2, then java -version shows me I'm using java 8. Back to the update-alternatives, select 0, java -version shows 11. Here's my output ...
user@amd:~$ java -version
OpenJDK 64-Bit Server VM (build 11.0.6+10-post-Ubuntu-1ubuntu118.04.1, mixed mode, sharing)
user@amd:~$ sudo update-alternatives --config java
There are 2 choices for the alternative java (providing /usr/bin/java).
Selection Path Priority Status
* 0 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 auto mode
1 /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111 manual mode
2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manual mode
Press <enter> to keep the current choice[*], or type selection number: 2
update-alternatives: using /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java to provide /usr/bin/java (java) in manual mode
openjdk version "1.8.0_242"
OpenJDK Runtime Environment (build 1.8.0_242-8u242-b08-0ubuntu3~18.04-b08)
OpenJDK 64-Bit Server VM (build 25.242-b08, mixed mode)
* 2 /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081 manual mode
Press <enter> to keep the current choice[*], or type selection number: 0
update-alternatives: using /usr/lib/jvm/java-11-openjdk-amd64/bin/java to provide /usr/bin/java (java) in auto mode
user@amd:~$
As a final step, I selected java 8, marked the jar file as exec, right click, open with jdk-8, it started.
I hope this helps.
Thank you very much Sir. It's working now.
Thank You, pavlos_kairis and Dave_Barnes. I really appreciate your help.
