Note: This post is a logical continuation of my question on AskUbuntu. I do not get results there.
I have bought new battery for my laptop. It is running Ubuntu MATE 16.04.5 LTS.
This new battery have normal capacity, charging and provides long life
But I have small problem: when battery level goes under some level - the laptop shutdowns immediately. I remember, that it normally went to the suspend with old battery.
With new battery I can suspend manually and all suspend-related tests (such as pm-is-supported --suspend, pm-is-supported --hibernate, pm-is-supported --suspend-hybrid) returns 0, so these actions are supported.
For more predictive results I have reseted all settings with
gsettings reset-recursively org.mate.power-manager
So my GSettings reports the following:
$ gsettings list-recursively | egrep "critical|action|low|time" | grep -i power | sort -u
org.mate.power-manager action-critical-battery 'hibernate'
org.mate.power-manager action-critical-ups 'shutdown'
org.mate.power-manager action-low-ups 'hibernate'
org.mate.power-manager action-sleep-type-ac 'suspend'
org.mate.power-manager action-sleep-type-battery 'hibernate'
org.mate.power-manager idle-dim-time 10
org.mate.power-manager info-history-time 21600
org.mate.power-manager notify-low-capacity true
org.mate.power-manager notify-low-power true
org.mate.power-manager percentage-action 2
org.mate.power-manager percentage-critical 3
org.mate.power-manager percentage-low 10
org.mate.power-manager show-actions true
org.mate.power-manager time-action 120
org.mate.power-manager time-critical 300
org.mate.power-manager time-low 1200
org.mate.power-manager use-time-for-policy true
In /etc/UPower/UPower.conf I have default values:
$ cat /etc/UPower/UPower.conf | grep -v ^# | egrep "Critical|Low|Action|Time"
PercentageLow=10
PercentageCritical=3
PercentageAction=2
TimeLow=1200
TimeCritical=300
TimeAction=120
CriticalPowerAction=HybridSleep
The MATE Power Management Preferences (mate-power-preferences) does not have GUI element to set critical battery level:
I have tried to change the percentage- and time-based values but system continue to emergently shutdown. So I can lose results of my work.
Where should I set critical battery level for hibernate or suspend from MATE GUI?
Will changing value via GSettings or Dconf change value in UPower.conf?
Where else should I set the action on critical battery level?
