As the title mentions, this relates to code used for dumping data (3D Model IGES export file) from disk to 9-track magnetic tape, which is what was used for exporting to outside sub-contractors (toolmakers) for manufacturing of "Plastic Injection Moulds". As is seen in one of the scripts, this was used in the context of HP-UX 5.3 in 1990.
There may be those who are still working with magnetic media in this fashion, so I offer these "production" level scripts which were used in industry.
Naturally, as with any evolving industry, some of this could be steamlined/optimized with more recent equivalents. ![]()
Three scripts and one C program involved:
- mtiges.1 - Job management script
- mtiges.dump - Data dumping script
- mtonline - Utility to ensure tape drive online and tape data track initialized before attempting to dump
- ck9trk.o - Program to test device readiness/online
Main program (mtiges.1):
# REVISIONS
# 90-03-27 Initial install of script
# define holding area for outgoing iges files
wherefrom="/users3/iges/IGES_OUT"
whereto="/users3/iges/IGES_SENT"
log="/users2/admc/igeslogs/`date '+%y%m%d%H%M'`"
/bin/rm -f $log
clear
echo "\n
TAPE DENSITY FORMAT\n
1 - 1600 bpi (default & industry standard)
2 - 6250 bpi\n
Enter selection => \c"
read dens
if [ "$dens" = "" ]
then dens=1
fi
case $dens in
1 ) read outputdevice <$ss/defaultiges
density="1600 BPI"
2 ) read outputdevice <$ss/denseiges
density="6250 BPI"
* ) echo "\n Invalid density selection" ; sleep 2 ; exit
esac
if [ "$outputdevice" = "" ]
then echo "\n DEVICE NOT DEFINED !\n Verify presence or content of $ss/defaultiges."
exit
fi
if [ ! -d $wherefrom ]
then echo "\n Directory $wherefrom could not be found.\n No files available."
mkdir $wherefrom
exit
fi
cd $wherefrom
if [ -s $ss/../ops/pending/igesfiles ]
then files="`cat $ss/../ops/pending/igesfiles | tee`"
echo "\n Using file names identified in $ss/../ops/pending/igesfiles ."
else
avail="`ls | tee`"
if [ "$avail" = "" ]
then echo "\n No files waiting to be dumped."
echo " Contact user to ensure data was sent to holding area.\n"
echo "\n Hit return to continue ...\c"
read a
exit
fi
clear
echo "\n FILES IN THE IGES TAPE CREATION POOL :\n"
ll $avail
echo "\n Dump all files to tape ? [y/N] => \c"
read doall
if [ "$doall" = "" ]
then doall="n"
fi
case $doall in
q* | Q* ) echo "\n Tape creation job abandoned.\n"
exit
y* | Y* ) echo "\n Will do all files."
files="$avail"
n* | N* )
files=""
for file in $avail
do
echo "\n Dump $file to tape ? [y/n] => \c"
read doit
if [ "$doit" != "" ]
then
case $doit in
y* | Y* ) files="$files $file"
echo "**** Name registered for tape dump."
* ) echo " No action taken for $file."
esac
fi
done
esac
fi
if [ "$files" != "" ]
then
echo "\n Enter banner for printout => \c"
read title
echo "\n Creation of IGES tape started !\n"
export files outputdevice
{ echo "\t\t\t\t`date`\n SYSTEM OF ORIGIN :\n\n
Platform: HP 9000 series 500
Operating system: HP-UX 5.3
Device drivers: UNIX system V compatible
Tape drive: HP 7978B\n\n"
echo " IGES TAPE FORMAT :\n\n
Tape Density: $density
File header record: no
Record length: 80
Blocking factor: 10
Character set: ASCII\n\n"
echo "\n\n\n\n\t\t\t\t`date`\n FILES CONTAINED ON THIS TAPE :\n\n"
ls -l $files
echo "\t\t\t\t`date`\n TAPE CREATION LOG :\n\n"
# settings="-x -r 80 -b 10"
# export outputdevice settings
# igesto $files
mtiges.dump y $files
echo "\t\t\t\t`date`\n END OF JOB \n\n"
clear
echo "\n IGES job is done.\n Log file is $log.\n" >/dev/tty
} >>$log 2>&1
pr $log $ss/mtiges.1 $ss/mtiges.dump | lp -dlp1 -t"$title VENDOR"
pr $log | lp -dlp1 -t"$title LOG"
wait
mv $files $whereto
else echo "\n No files selected. No action taken.\n"
fi
sleep 2
Script for dumping data to magnetic tape (mtiges.dump):
# REVISIONS
if [ $# = 0 ]
then echo "\n Start at begining of fresh tape ? [Y/n] => \c" >$tty
read bot
if [ "$bot" = "" ]
then bot="y"
fi
possible="`ls *.ige | tee`"
if [ "$possible" = "" ]
then echo "\n Directory $wherefrom was empty." >$tty
exit
fi
for file in $possible
do echo "\n Use $file ? [y/N] => \c" >$tty
read ans
if [ "$ans" = "" ]
then ans="n"
fi
case $ans in
y* | Y* ) files="$files $file" >$tty
* ) echo "\t\t $file ignored." >$tty
esac
done
if [ "$files" = "" ]
then echo "\n No files chosen for IGES dump." >$tty
exit
fi
else if [ $# = 1 ]
then echo "\n
usage : mtiges.dump [y|n] iges_file_name
y => start at begining of a new tape
n => search of end of tape mark before adding
" >$tty
exit
else bot="$1"
shift
files="$*"
then echo "\n No files identified on input line for IGES dump." >$tty
exit
fi
fi
fi
case $bot in
y* | Y* )
echo "\n Overwriting current contents of tape.\n\t\t Initializing ..." >$tty
touch /tmp/junk
case $outputdevice in
/dev/r7978iges)
tar cvf /dev/r7978low /tmp/junk
mt -t $outputdevice rew
mtonline /dev/r7978low
/dev/r7978diges)
tar cvf /dev/r7978 /tmp/junk
mtonline /dev/r7978
mtonline /dev/r7978
esac
* ) echo "\n Adding files to end of tape.\n\t\t Searching for end of tape ...\n" >$tty
mtonline $outputdevice
esac
for file in $files
do if [ -s "$file" ]
then echo "\n`date '+%T'`\t Doing $file ..."
echo "\n`date '+%T'`\t Doing $file ..." >$tty
cat $file | tr -d "\012" | dd of=$outputdevice ibs=80 obs=800
else echo "\t\t File $file not found.\n"
echo "\t\t File $file not found.\n" >$tty
fi
done
echo "\n`date '+%T'`\t Rewinding tape ...\n"
echo "\n`date '+%T'`\t Rewinding tape ...\n" >$tty
mt -t $outputdevice rew &
Script to ensure tape drive is ready for data transfer before proceeding (mtonline):
dev="$1"
val="`ck9trk.o $dev`"
while test \( "$val" = "2" \)
do echo "\007 $dev is off line. Please correct immediately."
sleep 60
done
set $val
echo " Device $dev is on line."
echo "$2" >&2 # file id to be used for putting the magnetic tape offline
# using the system subroutine "hpib_ren_ctl" man(3)
Program to test device readiness/online (ck9trk.c):
* ck9trk()
* test for online status of 9-track tape drive at device name passed.
* version 1.0 1987/04/15 by E. Marceau
* string with the value '2' is returned if the device is not online;
* otherwise, a message is returned as confirmation.
#define MAXLINE 80
main(argc, argv)
int argc;
char *argv[];
int len; /* line length */
char match[ MAXLINE ]; /* string to match */
char line[ MAXLINE ]; /* line from standard input */
int f1;
if ( argc != 2 ){
printf("Usage: t2 from\n");
exit(1);
if (( f1 = open(argv[1], 0) ) == -1 ) {
printf("2");
exit(1);
printf("1 %d\n", argv[1], f1 );
