Hello team I would like to get assistance as to how to install hitfilm express on my ubuntu system.
HitFilm is installable using Wine
https://appdb.winehq.org/objectManager.php?sClass=application&iId=19146
I would recommend to install PlayOnLinux first by sudo apt-get update && sudo apt-get install playonlinux and then install HitFilm using Install a non-listed program.
Thank you is there a step by step manual to follow since am very new to the system? Kind regards
