I'd like to experiment with an alternate display manager. dpkg-reconfigure lightdm doesn't bring up an option list. What should I be trying?
Thanks, Greg
Did you install an alternate display manager first before you run dpkg-reconfigure lightdm ?
I thought I had but after reinstalling I got the expected screen. Choosing a different display manager changed only the greeter however. No changes once logged in.
that is probably the only change you will see, changing the display manager does not change your desktop environment
Ok. I've learned something. Thank you!
